gas-tight flap after steam turbine
Hello friends,
The company which I work for is a contract engineer of waste incineration plant (with energy recovery). The 13 MW steam turbine is extraction-condensing type, with outlet diameter 1,8 m. The technical terms of reference states that after the turbine it must be installed gas-tight flap, opened in normal operation, and closed eg. when turbine breakdown will occur (then live steam will be directed by the bypass reducing-cooling station to the condenser). We are wonder if this solution makes sense, as the turbine and condenser supplier is of the opinion that this is not necessary - they want to inject water to the condenser at bypass operation. The prospective problems with that flap could be vibrations and noise during normal operation, as the velocity of the steam after the turbine is above 100 m/s. But these problems are only suppositions, we do not have any experience with this kind (and size) of flap between turbine and condenser. What do you recommend? Have you ever heard of such a solution?
RE: gas-tight flap after steam turbine
Doug
