vb step translator- issues on translating layer 0
I have this journal file that translates parts to step. but when i try to translate an assemble file with surfaces in it and on layer 0 they do not show. Can someone help! Below is the code i have so far.
'Purpose: automate STEP export of the following entities:
'Layer 1 - Solids
'Layer 4 - Solids
'Layer 5 - Solids
'Layer 41 - Lines
'Layer 44 - Points
'Layer 63 - Solids
'eng-tips thread561-321704: Step File Export Automation
'May 11, 2012
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module1
Dim theSession As Session = Session.GetSession()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim ufs As UFSession = UFSession.GetUFSession()
Sub Main()
lw.Open()
Dim strCurrentDate As String = Format(Today, "MMddy")
Dim mySelectedObjects As New List(Of NXObject)
Dim tempSelectedObjects() As NXObject
Dim step214File As String
dim pos as integer
Dim outputFile2 As String
Dim outputPath As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim outputFile As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
'look for position of hyphen
pos = InStr(outputfile, "_dwr")
'if hyphen is found, trim off all characters before hyphen (+1 to trim hyphen as well)
if pos > 0 then
outputfile = left(outputfile, pos - 1)
End if
outputFile = IO.Path.Combine(outputPath, outputFile & "_" & strCurrentDate & ".stp")
Dim STEP214UG_DIR As String = theSession.GetEnvironmentVariableValue("STEP214UG_DIR")
step214File = IO.Path.Combine(STEP214UG_DIR, "ugstep214.def")
'export to STEP214 file
Dim step214Creator1 As Step214Creator
step214Creator1 = theSession.DexManager.CreateStep214Creator()
step214Creator1.SettingsFile = step214File
step214Creator1.ObjectTypes.Solids = True
step214Creator1.ObjectTypes.Surfaces = True
step214Creator1.LayerMask = "1-256"
step214Creator1.InputFile = workPart.FullPath
step214Creator1.OutputFile = outputFile
step214Creator1.FileSaveFlag = False
step214Creator1.ExportSelectionBlock.SelectionScope = ObjectSelector.Scope.SelectedObjects
Dim added1 As Boolean
added1 = step214Creator1.ExportSelectionBlock.SelectionComp.Add(mySelectedObjects.ToArray)
Dim nXObject1 As NXObject
nXObject1 = step214Creator1.Commit()
step214Creator1.Destroy()
lw.Close()
End Sub
Sub AddSolidsFromLayer(ByVal layer As Integer, ByRef objList As List(Of NXObject))
Dim tempselectedobjects() As NXObject
Dim tempSolidObj As Body
tempselectedobjects = workPart.Layers.GetAllObjectsOnLayer(layer)
'filter out the solid bodies on the layer and add them to the export list
For Each obj As NXObject In tempselectedobjects
If TypeOf obj Is Body Then
tempSolidObj = CType(obj, Body)
If tempSolidObj.IsSolidBody Then
objList.Add(tempSolidObj)
End If
End If
Next
End Sub
Function SelectObjects(ByVal prompt As String, _
ByRef selObj As NXObject()) As Selection.Response
Dim theUI As UI = UI.GetUI
Dim typeArray() As Selection.SelectionType = _
{Selection.SelectionType.All}
Dim resp As Selection.Response = theUI.SelectionManager.SelectObjects( _
prompt, "Select Objects for STEP Export", _
Selection.SelectionScope.WorkPart, _
False, typeArray, selObj)
If resp = Selection.Response.ObjectSelected Or _
resp = Selection.Response.ObjectSelectedByName Or _
resp = Selection.Response.Ok Then
Return Selection.Response.Ok
Else
Return Selection.Response.Cancel
End If
End Function
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
'Layer 1 - Solids
'Layer 4 - Solids
'Layer 5 - Solids
'Layer 41 - Lines
'Layer 44 - Points
'Layer 63 - Solids
'May 11, 2012
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main()
lw.Open()
dim pos as integer
if pos > 0 then
End if
lw.Close()
End Sub
End If
End If
Next
End Sub
Else
End If
End Function
End Function
End Module
RE: vb step translator- issues on translating layer 0
www.nxjournaling.com
