Already Existing file - Create file with increment (1)
I have a journal file creates an image with a unique file name. I what I want to do is when the journal file is ran for the 2nd time I need the file name to create a (1) and increments (2) (3) and so one. Below is the code I have been working with if i could get some help, I would greatly appreciate it.
Thanks in advance!
Option Strict Off
Imports System
Imports System.IO
Imports NXOpen
Imports NXOpen.UF
Module Module1
Sub Main()
Dim theSession As Session = Session.GetSession()
Dim ufs As UFSession = UFSession.GetUFSession()
Dim workPart As Part = theSession.Parts.Work
'Get parent directory with IO commands
Dim directoryInfo As System.IO.DirectoryInfo
directoryInfo = System.IO.Directory.GetParent(IO.Path.GetDirectoryName(workPart.FullPath))
Dim strCurrentDate As String = Format(Today, "MMddy")
Dim tempSelectedObjects() As NXObject
Dim step214File As String
Dim Filenumber as Integer
'Dim outputFile3 As String
Dim outputFile2 As String
Dim outputPath As String = IO.Path.GetDirectoryName(workPart.FullPath)
Dim outputFile As String = IO.Path.GetFileNameWithoutExtension(workPart.FullPath)
outputFile = mid(outputfile, 1, 11)
outputFile2 = IO.Path.Combine(outputPath, outputFile & "_ANT_” & strCurrentDate)
If File.Exists(outputFile2) Then
filenumber = 0
Do
fileNumber += 1
Loop While File.Exists(outputFile2)
outputFile2 = IO.Path.Combine(outputPath, outputFile & “_ANT_” & fileNumber, strCurrentDate)
End If
Dim strPartJpg As String = ""
strPartJpg =outputFile2
ufs.Disp.CreateImage(strPartJpg, UFDisp.ImageFormat.Jpeg, UFDisp.BackgroundColor.White)
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
RE: Already Existing file - Create file with increment (1)
Check to see if the file already exists before the export. If it does, add an increment to the file name and test again. Repeat until you find a file name that doesn't already exist.
Here's some pseudocode:
CODE --> psuedocode
'generate base file name
myFile = "C:\temp\somefile"
dim i as integer = 0
do
  i += 1
  myFile & i
loop until NOT myFile.exists
www.nxjournaling.com
