Resize Curve NX9 with Use Curve Finder
Open the part resize_curve.prt then activate the sketch
Try to use Resize Curve
1°) Select one arc then Equal Radius in the Tab Result: 9 arcs are selected
RESET
2°) Select Equal Radius in the tab Setting then one arc: 10 arcs are selected
One arc is missing with the first approach
Am I wrong or is it a bug ?
Have a look a the video
Didier Psaltopoulos
http://www.psi-cad.com
RE: Resize Curve NX9 with Use Curve Finder
I tried this using NX 9.0.1.3 (the MR which will be available in a few weeks) and this seems to now be working consistently, whether you select the 'Equal Radius' option before or after you select an arc. Note that I'm working from home today so I don't have access to the original NX 9.0.0.19 version of NX so as to verify that this may not have been working correctly in that version. You could contact GTAC as they might be able to verify this for you.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Ok John Thanks a lot. I will contact GTAC
Didier Psaltopoulos
