Edge and Corner Columns
Hi To All
In two way flat slabs do you fix or pin the edge and corner columns???
RE: Edge and Corner Columns
Fixed, but use a 0.4-0.5 flexural stiffness modifier on the column. You may want to run your numbers to see what the stress is compared to P/A + M/S.
