Shaded view on drawing showing as wireframe in Creo View
I made a drawings with shaded views in Creo but when i open it in creo view it is come back as wireframe.
Any Ideas?
Any Ideas?
Michael McMillan
http://www.linkedin.com/pub/michael-mcmillan/53/37...
RE: Shaded view on drawing showing as wireframe in Creo View
Check the view properties to see if it is set the way you expect.
Michael McMillan
Thank you all for your help.
Michael McMillan
Michael McMillan
drawing_shaded_view_dpi 200 (decrease for smaller files)
Also note that shaded view output has a large rectangular block for each view and if they are too close together they will overlap and one will be blocked behind the other. It is definitely not WYSIWYG.
