Transverse eccentric shear load near support of round pin fixed at both ends
I need to calculate transverse shear force on 1inch dia X 3inch Long pin.
Pin is supported at fixed at both ends, cannot use Beam formulae since L<8D (short beam). The location of force is 1.86 inches from left end. There is direct single shear of this pin due to vertical load falling on it. Need to give the allowable veritcal shear load at distance of 1.86" from left support. Yield strength is 75 ksi, factor of safety - 1.5. As per my calculation allowable shear force is 7528 lbf. Please suggest, will be great help for me.
RE: Transverse eccentric shear load near support of round pin fixed at both ends
sorry, i'm confused ... is there one (transverse) load applied or two (vertical and transverse) loads ?
Quando Omni Flunkus Moritati
