Structural Steel Beam Retrofit
I have a two span W8x10 in which my client would like to remove the center support. They are trying to keep the costs down for the retrofit and I am planning on using a W12x22 to support the overlaying roof structure. I am planning on leaving the W8x10 in place and putting the W12x22 directly underneath it. Using the W12x22 vs. a WTx and welding it to the underside would save on a lot of welding in the field. It wouldn’t be the end of the world but I am afraid the small beam will all the wood connected to it might have deeper complications with fire and possible warping from all the heat. The question I have is that I have detailed bearing pads on top of the new beam to avoid any underside beam attachments from the adjacent ceiling and drags at either end. The problem I currently see is that as the beams deflect with a different radius of curvature the planned welding of the bearing pads to the underside of the existing beam could possible shear through as I am only placing them at 7’-0”o/c. Whether or not I have them fully unshore the beam above before welding still would present a problem when live load is introduced. At least in my mind. I woke up this morning picturing people in a restaurant eating dinner then a big pop as one of the welds failed. Any thoughts or feelings on my situation? Maybe I’m right maybe I’m wrong. I haven’t submitted yet and if it only meant me changing my detailing a little that would be great. Possible single pad at center for a point load on new beam? Thank you in advance for all that share and add to this thread!
-Tom
-Tom
RE: Structural Steel Beam Retrofit
What about just running the (n) beam from (e) far column to column and only connecting it there. Then provide a shim at the end of the W8 where the column was removed. A small plan in the area would also help.
This way you're not considerd with VQ/I of the two shapes together, and also you can jack the roof up slightly before inserting the shims to essential pre-load the W12x22.
And now you just have a simple tack weld to hold the shim in place.
