Catia Law Editor Syntax Problem
Hello Friends,
I want to create curve defined by following formula.
Y = Rc-sqrt(Rc*Rc-X*X*L*L)+K*(X*L-Rb)*(X*L-Rb)*(X*L-Rb)
Y is evaluated w.r.t. X
Here Y and X are formal Parameters of type Real
Rc,L,K,Rb are Parameters of type Length (in mm)
I get bloody old bullshit error "Units are not homogeneous" when I put same into Law Editor
I think I have to thoroughly understand the unit conversion rules. Can anyone enlighten me on same ?
RE: Catia Law Editor Syntax Problem
but Y= X + L/1mm is ok
also you can not write SQR ( mm^2 - mm^4)
What you can do is create L1 (no unit) = L / 1mm and replace L with L1 in your formaula...it might be easier than puting /1mm everywhere :)
if I convert X and Y into Length Type, will it solve my problem ?
