Building Expansion Joint
I am working on 1 story apartment building, approximately 28'x163'. It is 2x4 construction with wood roof trusses. Do you guys think it needs an expansion joint anywhere? (See attached pic)
I have never seen an expansion joint in a wood framed building of this size, but I was curious about other engineer's experiences.
It will be constructed in eastern NC.
Thanks in advance.
Thanks in advance.
RE: Building Expansion Joint
_________________________
Tony Krempin, PE
TopKnot Engineering
Do you think the cracking will be distributed enough so as not to cause separations in the exterior walls?
Maybe I can install cold joints in the slabs under every other unit?
