Machining data library - drilling
When I try to add new item to the database, drilling parameters, it gives an error, see attached.
What values should I add to cut depth and stepover?
Is there any context between the cut depth and the maximum hole depth?
How can I store drilling technology data such as step values?
My goal is to set up tool database for feature based drilling and hole milling. Do I need machining database for it at all?
Which is better: define technology parameters at 'machining data' Or at 'tool machining data' ?
Thanks in advance
Thanks in advance
kukelyk
RE: Machining data library - drilling
When I go to tools --> Edit Machining Data, and add an entry for a drill, it works fine.
You need to at least enter a tool diameter and length. The stepover and depth of cut are not required.
Mark Rief
Product Manager
Siemens PLM
I tried it in NX9, and I noted the new check boxes next to the above parameters. Great.
What are You suggest me for the second part of my first post?
kukelyk
Tool machine data is used to bypass all of the calculations based on tool material, part material, tool rigididty, cut method, etc. It is used when you have a specific set of parameters for a specific tool. For example, you have a chamfer mill that you always run at 5000 RPM and 30 IPM, no matter what material you are cutting. Here you would assign tool machining data.
Mark Rief
Product Manager
Siemens PLM
How can I store other drilling technology data such as step values?
kukelyk
Mark Rief
Product Manager
Siemens PLM
kukelyk
Mark Rief
Product Manager
Siemens PLM
