Failure Mode
Failure Mode
Failure Mode
Dear Engineers,
Can i know what kind of failure mode that can happen on the wing spars, wing stringers, wing ribs and wing skins of an aircraft and it would be helpful if i can know the loads that cause that particular failure(s)
RE: Failure Mode
Yes, you can know all of that.
All you have to do is reverse-engineer an aircraft.
I suggest you pick a really old model.
Mike Halloran
Pembroke Pines, FL, USA
RE: Failure Mode
read an airplane design book ... Raymer, Toreenbeek.
if you're particularly intereted in structures, read Bruhn.
Quando Omni Flunkus Moritati
RE: Failure Mode
hsinid,
I am under the impression that bad things happen when you smash into stuff.
JHG
