Macro to check missing parameter and add those in both part and product.
Hi I'm new to programming, and sorry for stupid questions.
I am trying to make a macro including functions below:
Exactly I got several types of parameters and I want to check they are in every part and product in my CATIA module. If some of them are miss, they would be added in.
please anyone can help me.
L
L
RE: Macro to check missing parameter and add those in both part and product.
Did you start to code something? Where is the problem? What kind of help do you need? A little bit more details...
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
Option Explicit
Public Sub CATMain()
'CATMain requires the user to have selected a Product item from the tree
'1. Going to make a list of parts and products
'2. a) Evaluate each one to see if it is missing any parameters
'2. b) Generate any missing parameters
Dim prdTest As Product
Set prdTest = CATIA.ActiveDocument.Selection.Item(1).Value
GetSubProducts prdTest
checkmissingprameter prdTest
End Sub
Public Function GetSubProducts(prdInput As Product) As Collection
'Makes a list of all the sub parts and products within prdInput
Dim i As Integer
Dim prdChild As Product
Dim prtChild As Part
Set GetSubProducts = New Collection
For i = 1 To prdInput.Products.Count
Set prdChild = prdInput.Products.Item(i)
Next i
End Function
This is what I've done right now.
Then I want to create something like a parameter database including some parameter I want to check.
and then add missing parameters.
I've updated it, but I dont know how to make "check" function.
any tips?
Option Explicit
checkmissingparameter prdTest
End Sub
Dim i As Integer
Next i
End Function
Public Function checkmissingparameter()
Dim parameters1 As Parameters
Set parameters1 = product1.UserRefProperties
Dim strparam1 As strparam
Dim strparam2 As strparam
Dim strparam3 As strparam
Dim strparam4 As strparam
Dim strparam5 As strparam
Dim strparam6 As strparam
Dim strparam7 As strparam
Dim strparam8 As strparam
Dim strparam9 As strparam
Set strparam1 = parameters1.CreateString("A", "")
Set strparam2 = parameters1.CreateString("B", "")
Set strparam3 = parameters1.CreateString("C", "")
Set strparam4 = parameters1.CreateString("D", "")
Set strparam5 = parameters1.CreateString("E", "")
Set strparam6 = parameters1.CreateString("F", "")
Set strparam7 = parameters1.CreateString("G", "")
Set strparam8 = parameters1.CreateString("H", "")
Set strparam9 = parameters1.CreateString("I", "")
End Function
