Galvanic Corrosion Between Inco 625 and K500
Will galvanic corrosion occur between Inco 625 and K500 material? I have a customer who wants to buy a Inco 625 Socket Head Cap Screw along with a K500 lockwasher. The environment will be subsea. I offered a K500 lockwasher b/c you can get a "true" lockwasher in this material where as with Inco 625, you are basically getting a flat washer that is split.
Greg
System 22, Inc.
RE: Galvanic Corrosion Between Inco 625 and K500
If it is less corrosion resistant then either then there is no issue.
I doubt that there will be problems, though in the past I strongly favored using K500 for washer and bolt.
Plymouth Tube
Greg
System 22, Inc.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
