camber in concrete beams
Can someone show me where is the camber factor (mild steel and PT) requirements called out in AASHTO LRFD Bridge Design Specifications?
RE: camber in concrete beams
Are you referring to the constant for camber creep? If so I believe it's somewhere in Section 5.4 point something. Sorry but I don't have my copy with me.
5.7.3.6.2—Deflection and Camber
