The use of 25KV rated equipment on a 26.4KV primary?
I have a pad mounted transformer rated: 750KVA,3 PHASE, Y-Y, 15.24/26.4KV - 277/480V. The rep. is telling me that i can use a class rating of 25KV,125KV BIL instead of 35,150KV BIL for insulation, but i am still not 100% convinced it is 26.4kv on the primary how can i get away with 25kv rated equipment?
any inputs are appreciated, thank you
RE: The use of 25KV rated equipment on a 26.4KV primary?
26.5kV- 150kV are system maximum voltage and BIL voltage of another standard;
system voltage is phase-to-phase; metering tests are normally phase-to-ground.
the next standard rating for the (bushing,load break connectors, surge arrestors) is 35KV
If you require 200 kV BIL, then that would be 36 kV class equipment.
You have to use 25 kV class bushings, arrestors, etc...for 150kV BIL grounded system ( i guess your 25.6kV is effectively grounded system).
I would assumme 25 kV-150kV class bushings, arrestors, etc...
