heat transfer between two surfaces
Hi
I'm trying to model radiation between two surfaces(there are two seperated models).
i tried to define cavity radiation for both of them and i chose closed form(in the Interaction part,(cavity radition)
when i want to get results there is an error about Viewfactor and it says that there is no ambient temperature.
so i tried Open(when defining Cavity Radition)and i defined the ambient temperature this time it runs successfully but the answer is wrong because it only shows that both surfaces and their whole bodies have the same temperature of ambient.
p.s one of the surfaces has much higher temperature than the other surface and much higher than ambient's temperature(for the warmer surface i used Boundary condition(so that it stays constant) and the other colder surface has initial condition for it's temp)
please help me
you can see my model in attachment
thanks
please help me
thanks
RE: heat transfer between two surfaces
the right one has higher temperature
