NX4 problems in windows 7 x64
Hello, I NX4 version does not work well on Windows 7 x64, when I pass the mouse over a figure, all surfaces and takes a long time to finish select are selected, this happens to me with the graphics drivers that puts Windows default .
If I upgrade the graphics drivers to the latest version, it does not, but then when I throw a reproduction machining draws slowly moves.
We have tested three graphs:
Integrated intel 4600
Nvidia 8400GS
Nvidia 8800GT
With all three have the same problems.
Does anyone know how to solve these problems?, Windows XP so far we had no problems.
Thank you very much.
Nvidia 8400GS
Nvidia 8800GT
RE: NX4 problems in windows 7 x64
www.nxjournaling.com
Thank you.
They must be paired or you get problems.
I doubt Windows 7-32 will help as it is also not certified for NX4.
Your best solution is to build a xp-32 box.
Ben Loosli
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
There is NO solution for Windows 7 that will be satisfactory.
Graphics drivers may work somtimes, but I've never seen them fix the problem permanently, issues always arise.
Also your graphics cards are gaming not workstation cards and the Intel HD is the worst possible graphics chip to use with NX.
Your only option is to use Windows XP as that's what NX4 is designed for, or update to a version of NX designed for Windows 7.
Anthony Galante
Senior Support Engineer
NX5.0.6, NX6.0.5, NX7.5.5, NX8.0.0 -> NX8.0.3.4
NX8.5.0.23 -> NX8.5.2.3 & NX9.0.0.19
with a NVIDIA Quadro 2000
I works fine No graphics issues.
Although I only use it for some legacy files that we will be moving to NX7.5 in the future
John Joyce
N.C. Programming Supervisor
Barnes Aerospace, Windsor CT
NX6, NX7.5 & NX8.5
Vericut7.2.3
I'd highly suggest a graphics card change to at least the lowest entry level "pro" card (probably NVIDIA being your best bet). i hate suggesting this (because i loathe the whole fake/forced "pro-cards-cost-more-then-they-should-coz-oh-its-the-drivers-bro BS!) but in your case its probably a good thing to try to alleviate your issue. I have a Quadro 4000 and i still get issues with "fully qualified" software with these oh-so-pro-expensive-and-qualified-drivers-and-hardware. :P
"upgrade your version of NX". Like as if it was a free download... come on guys, i expected a more honorable response from you guys! Not everyone has an unlimited pit of money to spend on a hope for a bug fix. It's not just another file copy operation=sale for some of us! And more obviously... often its not even our choice (because you know we would if we had the actual chance). :P
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thank you.
Try any Quadro level card, not a GeForce one.
Ben Loosli
Try any Quadro card BUT stay away from the Quadro NVS cards!
- The NVS cards are not for 3D.
Tomas
Thank you.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
CAD programs are not like Office were you can upgrade the OS and keep using an older application. The application is designed with certain OS requirements.
NX4 needs to be installed on WinXP-32 on a computer with a Nvidia Quadro graphics card. IF you have the 64-bit version of NX4, then XP-64 could be used.
You still haven't answered WHY you cannot run a newer version of NX?
Ben Loosli
I think we know the answer... ;) Btw, I felt bad having been on NX6 till end of last year. Now on 8.5, it's way cool!
Bill
Ben Loosli
