Novec 1230 Gaseous System Venting
I can't seem to find the answer to this. Does the use of Novec 1230 require exhaust? My understanding is that inergen does not, FM200 does but all I can seem to find on Novec 1240 is that is has no impact on environment.
RE: Novec 1230 Gaseous System Venting
FireFreak08 (Mechanical)
Can you give an NFPA reference or other where you see the FM200 is required to exhaust.
0.5 seconds of googling yields:
http://multimedia.3m.com/mws/mediawebserver?mwsId=...
"Q: Is there a requirement to have a dedicated ventilation system
to remove Novec 1230 fluid after a discharge?
A: An active mechanical process that is designed to remove Novec
1230 fluid/gas from the protected space is not required by any
of the recognized codes or standards. That said, the designer
of a system using Novec 1230 fluid may consider use of such a
ventilation system on a case-by-case basis if conditions warrant,
similar to what has been done in the past with halon."
23. Is there any post-activation purge/ventilation requirements for your system?
There is no requirement within NFPA 2001 for a dedicated exhaust system when using DuPont™ FM-200®. NFPA requires that the post-extinguishment atmosphere be ventilated in a safe manner. With most installations, this can be accomplished by simply turning on the air handling units and allowing enough time to dissipate any smoke in a post-fire event.
Some jurisdictions have implemented additional local requirements concerning ventilation systems. You should check with your local authorities.
http://www2.dupont.com/FE/en_US/products/FM200_faq...
Evidently I suck at using google. banghead
@cdafd : My original post wasn't very clear. I meant there are certain municipals in my area that require FM200 to be exhausted.
