Pattern Text With Increment
Hi Everyone,
Hope everyone had a nice holiday and Happy New Year!! I am working on a fixture in NX8.5.2 and am stumped... I have a pattern of dowel pin positions for where an operator can drop a fixture and would like to add some text to each setup position something like this:
02 04 06 08 10 12 14
O O O O O O O
Legend:
Dowel Hole: 0
Scribe Mark: |
The is it possible to control the reference text value using the "Use Spreadsheet" Button inside of the pattern command or somehow control it via pattern increment?
I tried making a dummy sketch with a line in it, patterned it, and set the line length dimension to increment by 2 in the pattern increment window and was able to get the length of the line to grow. Can i get each instance of the text to then call back that value? It seems like a work around but got stuck on getting the text feature to reference. Any other ideas? I know I could write some code but I'm trying to avoid that.
Thank you,
-Patrick
Thank you,
-Pat
RE: Pattern Text With Increment
All,
My ASCII Art image didn't quite work out as well as expected, The "|" and the text should line up with the O's but you get the concept the main thing is getting the text to increment the formatting is easy.
-Pat
Thank you,
-Pat
