welding of pipes 30 inch
How can tow pipes of 30inch diameter with different wall thickness(9.5mm,13mm)be welded and what's the procedure for welding?
welding of pipes 30 inchwelding of pipes 30 inch(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: welding of pipes 30 inch
What you don't say is what the respective grade of pipe is between 9.5 and 13mm. If it is the same grade, then internal machining to reduce the 13.5mm to 9mm is acceptable as shown in the post above. If the 13.5mm pipe is made from a lower strength grade, then it probably is not. Also is the ID the same or the OD? If OD is the same then it is more difficult than if the ID is the same as shown in the first post by denlow.
What you need if the grades are different is a transition piece made of the higher grade material with one end 13.5mm wall thickness and the other machined at not less than 1:4 ratio to 9mm, then end prep'd in the same way as normal.
thanks
mark
you have two options, first ( BS EN 1011-2:2001 page 12 ).
but ( BS EN 1709-1:2010 Table 1 is explain this matter clear )
Denlow
