About loads for testing a new vehicle
Hi all,
It's well know loads on a vehicle are strongly dependent by vehicle parameters itself and they can be different markedly from a vehicle and a similar one (as example from the old mercedes c-class and the new one). It's also well known that measuring the loads on a prototype is time consuming. What is it commonly carried out from vehicle companies? Are testing loads measured anytime a new prototype is built in some conditions?, Are they computed from multibody simulations? Are they measured only once every a couple of new vehicle and correct somehow as example using the GCW?
thanks
thanks
RE: About loads for testing a new vehicle
No, because the time pressure on prototpyes is high and collecting road loads is a time consuming and expensive task. one approach is to measure the road loads after the design is complete and check that the road loads that were used to design the vehicle were conservative.
This is the Holy Grail for durability. Unfortunately, given a known road surface profile and a typical vehicle MBD model it is not possible to predict the loads to sufficient accuracy. The problem is worst on the sort of events that comprise the greatest damage dose. We are getting there, for example I have included a cherry picked comparison between the real vibration spectrum measured on a car and the results from running an ADAMS model over the same measured road surface. If they were all of this standard then I might have some confidence in the whole procedure. Note the very restricted frequency range (I used a 1-6 hz bandpass filter in post processing), this has to be vastly increased to be useful for fatigue life predictions. I'd also add that looking at spectra is handy for corrletaion but of course is not directly related to fatigue calcs, if you were to try and predict fatigue you need a different approach entirely.
Are they measured only once every a couple of new vehicle and correct somehow as example using the GCW? Yes, that is a typical approach. It woud be wise to use an additional scaling factor to account for the uncertainity.
Cheers
Greg Locock
Thanks for your reply.
Is it done for any new vehicle or once every few releases of the new vehicle? What's happen if the design loads are not as conservative as requested?
If the measured road loads were found to be greater than those that were used in the design then a late design change could be made. Fixes might include: additional reinforcement, retune of suspension components such as shocks and jounce bumpers, or modifications to the allowable GVW of the vehicle. This breaks program discipline to some extent, as with all late changes extra oversight should be applied.
This all sounds a bit uncontrolled, but managing a few late changes is vastly preferable to the old way of doing it, where everything was changing right up to 6 months before Job 1.
Cheers
Greg Locock
Here again on this topic. I have just read this SAE paper (http://papers.sae.org/2003-01-3436/), that is about the flow procces of developing new transmission. In it, there is the following sentence: "Component load-life relationships, i.e. component SN curves, must be developed for each component and failure mode.". For transmission there are many failures mode, since each one should be tested with two amplitude levels, that process is timeconsuming. Moreover for designing new transmissions the SN curve must be known, but it's not because the transmission is not tested. So how manunfactures usually deal with this issue?
Cheers
Pietro
Cheers
Greg Locock
You know what the gears will take. You know what the clutch-packs will take. You know what the hydraulic actuators will take. You know what the bearings will take. Put it all together. Then test to verify that you didn't goof the design and to hopefully catch what was missed in design.
25 years ago one of the major school bus companies got a HUGE order for buses in the middle east. However, the way vehicles are used in other countries differs. The buses they shipped over broke down within weeks. Seems a vehicle built for 35 in here needs to carry 3x that number plus a few goats over roads that wouldn't be rated for a jeep in the US. In the end, this huge order put the company out of business and it was sold.
Cheers
Greg Locock
how do manunfacturers usually comply with this Local Market Requirements? Do they change the warranty specifications for each market?
Can also 4 post rigs run 24hours per day as transmission rigs?
I hope you aren't trying to use a 4 poster for general durability testing.
Cheers
Greg Locock
Why wouldn't you use a 4 poster for general durability testing?
Cheers
Greg Locock
The cycles and loads used for a transmission component fatigue life analysis are based on a composite of several operating conditions, and there are many different analysis cases with different conditions performed for each component in the system. The components are designed by analysis, and testing is used to validate the analysis work. Since calculated fatigue life of transmission components is a statistical number, it is usually not practical, in terms of cost or schedule, to test a statistically valid number of transmissions for their design life.
thanks you're providing me very useful information. In our case, we want to test a not suspended vehicle with a spindle coupled rig, but at our company we call it improperly 4 post rig.
Tbuelna,
thanks for your reply. So how many transmission are usually tested? Only one?
Cheers
Greg Locock
Think of the situation in these terms- If you have say 36 months to design a new transmission, test it, and get it into production, do you think it would be possible to complete a 2500 hour lifecycle test on a dozen or so production conforming transmission test articles in that timeframe? Probably not.
Fatigue testing of transmissions usually involves testing at many different conditions, including accelerated testing at elevated load/speed. The risk of getting the design of a production transmission wrong can mean millions of dollars in warranty costs for the OEM. A Weibull analysis based on just 3 data points would not be satisfactory for an automotive OEM.
so dozen is impracticable and 3 is not that much. So I believe the number of samples is dependent but the possible number of the different failure modes, that each one should be tested; in case of a transmission there are at least 4 failure modes (i.e. gear tooth bending, gear tooth contact, roller bearing, ball bearing) so I wuould believe 8 transmission samples is the min number, is it right?
The type of test you are asking about is called a "qualification test". The purpose of a qualification test is to validate the design and analysis work behind the device being tested. Things like auto transmissions are certified based primarily on critical reviews of analysis reports for things like stress, fatigue, dynamics, reliability, failure modes/effects, performance, etc. Due to the large number of potential failure modes a complex system might have, and/or the huge number of load cycles required to test an individual component to its predicted fatigue life limit, these variables are often only validated by analysis work.
If you're going to conduct a bonafide qualification test on a transmission, the test article should ideally conform to production standards. And this would require using transmission components that were produced using production materials and processes. If these conforming components are not yet available for the qual test article, then the only alternative is to use components that were designed, analyzed and manufactured using existing processes that were validated by previous qual tests.
The analysis and testing of something like a new auto transmission design is no small matter. Due to the slim profit margins the OEM makes on production auto transmissions, if their calculated reliability of the transmission is off by a small percentage, the warranty replacement costs can result in huge financial losses for the company.
