Up to What height is required to drill slot holes on stilling well ?
I have a question on the large crude oil tank with internal floating roof, can we drill the holes up to HHLL? Is any evaporation loss a big concern? Or keep the holes under LLLL?
Thanks for any inputs.
XZS
XZS
RE: Up to What height is required to drill slot holes on stilling well ?
Thank you very much.
XZS
Emission Factor Documentation for AP-42
Section 7.1
Organic Liquid Storage Tanks
Final Report
page 8 paragraphs 7 and 8 describe the difference between slotted and un-slotted.
7. Unslotted guidepoles and wells. A guidepole is an antirotational device that is fixed to the
top and bottom of the tank, passing through a well in the floating roof. The guidepole is used to
prevent adverse movement of the roof and thus damage to deck fittings and the rim seal system. In
some cases, an unslotted guidepole is used for gauging purposes, but there is a potential for differences
in the pressure, level, and composition of the liquid inside and outside of the guidepole. A typical
guidepole and well are shown in Figure 7.1-11.
8. Slotted (perforated) guidepoles and wells. The function of the slotted guidepole is similar
to the unslotted guidepole but also has additional features. Perforated guidepoles can be either slotted
or drilled hole guidepoles. A typical slotted guidepole and well are shown in Figure 7.1-11. As
shown in this figure, the guide pole is slotted to allow stored liquid to enter. The same can be
accomplished with drilled holes. The liquid entering the guidepole is well mixed, having the same
composition as the remainder of the stored liquid, and is at the same liquid level as the liquid in the
tank. Representative samples can therefore be collected from the slotted or drilled hole guidepole.
However, evaporative loss from the guidepole can be reduced by modifying the guidepole or well or
by placing a float inside the guidepole. Guidepoles are also referred to as gauge poles, gauge pipes, or
stilling wells.
