Which Sprinkler Should i propose ?
Which Sprinkler should i propose for a ware house having Height 11.5 meter and Storage Height is 8.5 meters .The Material is stored inside multiple row rack with wooden pallets .Asile Width is 4.6 m and clearance is 75 cm.
RE: Which Sprinkler Should i propose ?
To many variables to get an Internet answer
Should hire a fire protection engineer
The material stored inside the rack is wooden furniture.
Lots.
What kind of construction for starters, pitch of roof and that sort of thing. Placement of structural members remembering it is impossible to install an ESFR system in bays measuring 7 meters at heights you suggest.
What's your water supply? This alone will have a lot of impact on what head to use.
I wouldn't select a head unless I was prepared to design the entire system and you shouldn't either. Do yourself a favor and leave the design up to the qualified individual.
There are alot of parameters need to consider before you can select a sprinkler for a warehouse project.
Kindly go through NFPA-13 chapter 13-20 to have an idea regarding the required information.
