What is the difference between Fabrication and Manufacturing?
Given that a company is producing the same Parts/Assemblies:
What is the difference between a Fabrication Operation/Company & a Manufacturing Operation/Company?
What would be some of the main undertakings in transforming a Fabrication Operation/Company into a Manufacturing Operation/Company?
No, this is not a school question.... This is a question that often comes up in my workplace. I'm interested to see if the general conceptions coincide with mine & my coworkers.
VS
VS
RE: What is the difference between Fabrication and Manufacturing?
Fabrications are usually not the end product being made. My company purchases many fabricated parts and then welds the parts together to make a chassis, cab, and loader arms. These parts are then assembled into a skidsteer loader or a compact track loader. The loaders are the end product while the fabricated parts and the weldments are all considered fabricated components.
Bill
Fabrication involves the use of skilled workers. Drawings/specs are given to those workers who decide themselves how best to make it, on what machines, and how long it should take.
Manufacturing involves relatively less skill. It relies on a much fewer number of skilled workers to setup the operation (jigs/fixtures, Work instructions, standard times.etc) so that a comparatively larger number of unskilled workers can produce parts in the same quantity and quality.
Perhaps my terminology is wrong for the two cases?
When I hear fabrication I think of metal fabrication that is mostly welding, riveting, bending...
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
A starting company with a new product may begin with "Drawings/specs are given to those workers who decide themselves how best to make it, on what machines, and how long it should take" as the effort required to produce the tooling, detailed drawings, instructions.etc is top heavy compared to the production effort. Setup in a cellular fashion. Possibly make-to-order
Once demand grows & production does as well, there is a shift to a "fewer number of skilled workers to setup the operation (jigs/fixtures, Work instructions, standard times.etc) so that a comparatively larger number of unskilled workers can produce parts in the same quantity and quality" and often a gain in efficiency as well. Moving toward more of a choreographed mass production fashion. With pre-set models & options.
Any ideas?
This is what I was afraid of.
As far as what vonsteimel is asking I would just say that was pre production against production. Certainly in automotive it is normal to produce pre production parts off tooling but that have additional hand work done to them or that are made in a different way to the mass production parts.
Unfortunately when meetings take place on a largely unplanned & sporadic basis with various outsiders, there isn't time to go through definitions & terms. You've just got to fly by the seat of your pants... Finding common terminology as such, can be difficult but useful.
In discussions, more commonly I've heard people say that we're in a "Job Shop" setup. This does not adequately define our technical situation, as its much more than just a modus operandi...
I find that most people think "sheet metal" when they here fabrication.
