What is the difference betwwen Reduced bore valve and Full bore valve
Dear All,
I required some number 1" AL Bronze ball valve 4 - 8 bar pressure for a project I'm working on. The client specified Reduced Bore, A well known supplier qouted Full bore valve, considering the pipe size and flow rate accros the pipe there is no or minimal pressure drop.
Please advice on this issues.
RE: What is the difference betwwen Reduced bore valve and Full bore valve
David Simpson, PE
MuleShoe Engineering
Law is the common force organized to act as an obstacle of injustice Frédéric Bastiat
At 1", the cost difference is not so much and your supplier has given you something a bit better. Only you know if this costs more than another supplier offering reduced bore....
