surface for 3D Closed Curve
Hello All,
Please i need help.I need to create the Surface for the Closed 3D curve as we create in catia V5 with Fill Command. I have attached the file containing crve for which surface needs to be created.
I am using NX8
Thanks in advance
BGD
I am using NX8
Thanks in advance
BGD
RE: surface for 3D Closed Curve
thread561-354120: Fill the gap or hole in the NX8
If you don't give any new information, you won't get any new answers.
What's the actual application?
You only have a 3D curve by itself out in space (as in your example file)?
You have a hole in an existing surface?
Are you trying to match up to other existing surfaces?
www.nxjournaling.com
John L.
NX Support
Win 7 64bit NX 7.5.4.4 TC 8.3.1.1
I agree with you it is a old question . since i got answer for hole in the Surface and it was perfectly ok using the patch opening or delete edge command to fill hole in the surface.
but now with 3D 3d curve in space, i am not getting good surface with N-Sided. however i create it using the through curves by creating cross curves. but i need better way please..
So only N-Sidede is the way to fill the curve or are there any wasy to do it??
Thanks in Advance..
BGD
You can for example also fit a surface onto the curve, but since we do not know the shape you want, it's hard to advice.
Tomas
There are lot of different interpretations from the curve you have shared with us. The final output surface using N-SIDED will depend on other supporting inputs also (constrain faces ).
I am attaching a video file herewith and also the part file (in NX8) ...
You will see that in the last of the part file i have used just a plain extrude and trim sheet to get a more clean output (besides the N-SIDED surface as shown in video).i would have used this one (although it takes 2-3 steps but it gives the best clean surface ...i admit it may not be a case everytime but when possible i have always tried to use basic operations to get the final surface. You can check the Control point structure of the resulting face (rectangular grid) as compared to other methods.
Also please do check the curve quality (you will see a small gap also however small but still it is there ...in addition to the abrupt changes in the curvature comb).
Best Regards
Kapil Sharma
Thanks for the possible options. here was trying to compare surfaces created in Catia with fill command and the surface created in NX with N-sided without the constraint surfaces
in either softwares.
Thanks all.
BGD
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
