Static Equilbirium analysis error
I was trying to run a suspension analysis and in turn I get the following error in Adams/Car
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was contact Comp = 5 Error = 705141.910177
The variable receiving the largest increment was fix Comp = 5 Delta = 563645957.821714.
ERROR: Simulation failure detected.
How to rectify this error??
Looking forward for some useful answers
RE: Static Equilbirium analysis error
1)Increase MAXIT
2)increase ERROR (this is often a bad idea, reducing ERROR is often just as helpful)
3)Use STATIC FUNNEL
Of course far more likely is that your model has some typoes in it.
Cheers
Greg Locock
