Pickling and passivation of 304 stainless steel drums
Dear all,
I am asking vendors to bid on several 304 SS drums with pickling and passivation. I got one bidder refuse to provide pickling and passivation with the following reason.
Quote "Pickling and passivating is done on A-403 stainless fittings. It is not done on Sect.VIII pressure vessels. We would be happy to work with you toward satisfying your metallurgical concerns on certain internal surfaces. Let's begin a dialog and discuss your concerns.” Further, if you know of service companies that can pickle and passivate whole vessels as large as 144”ID x 36’ T/T, we would like to be aware of them, so please share their identities with us." Unquote.
Is it correct from the above statement there is no need to pickle and passivate ?
(I have other bidder who has no problem of doing so by sub-contracting the work out)
RE: Pickling and passivation of 304 stainless steel drums
Pickling and passivation is between the customer and supplier. General boiler subcontracts the service. The supplier you mention should find a capable company and bid the job. Its a hassle to deal with pickling and passivation since the fabricator has to do some of the preparation and it is expensive. No problem to perform on 304 316's materials. Genb
I have seen pickling and passivation on many 304 and/or 316ss pressure vessels and heat exchangers (as requested by the customer). Some done in-house and others performed by a contractor.
ugly
It's very common practice to pickle and passivate or even electropolish a 300 series vessel. I see it done all the time within the pharmaceutical and food processing industry. Granted for a vessel of that size, you will need to find a special outfit that can do it. There are a number of outfits in Texas that specialize in large vessels. Here are some resources to start your hunt:
http://www.alleghenysurface.com/index.php?src=dire...
http://www.delstar.com/
http://www.harrisonep.com/passivation.html
http://www.ableelectropolishing.com
Often op large structures the pickling is just done on the welds. Often a paste a is used for this localized process.
Then the entire unit is passivated, often using a spray system and recirculating the acid.
I have worked with a couple of the guys mentioned above. They know how to do it.
Plymouth Tube
