Set Modifiers In ETABS
Dear All,
In ETABS while assigning the frame section we give certain values in SET Modifiers option. Especially for torsional constant, Moment of inertia abt 2 axis, Moment of inertia abt 3 axis.
On what basis do we give these values. For eg if am using a Column of size 200x600mm what will be the Set modifiers that I have to give? please help me guys...
RE: Set Modifiers In ETABS
I have found that unless it is an equilibrium torsion than the column element will not be too sensitive to variations in the torsion modifier.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
