Hydraulic test pressure of Tube bundle as per TEMA R
Dear Experts
what is the formula for calculating Hydraulic test pressure of Tube bundle constructed as per TEMA R 2007 edition?
Basically I do not have the TEMA R 2007 code at the moment but I wonder if the calculation is the same as ASME VIII UG 99.
REGARDS
RE: Hydraulic test pressure of Tube bundle as per TEMA R
MareiHamad, off top of my head, if TEMA says anything about hydrotest pressure, it will refer to Code of construction.
Mike
