directional component of earthquake
hi all
i need your help with my case of study , when the quake epicenter placed in a position of south-west of the building that i need to design ,while i have a three seismic records ( one in each direction N-S,W-E,up ) that recorded in a station that has s different directional orientation of that building ...
whats the solution for this case ??
RE: directional component of earthquake
Since time histories are just a list of discrete data points, you could also just rotate each pair of horizontal data points. You could use linear algebra and attack the problem with a rotation matrix of some sort or throw them all into excel and fake it.
If this isn't an academic study or investigation of actual past performance I'd be concerned that you're trying to model an earthquake to this level of precision.
