impact load factor for HVAC air handling unit
The HVAC air handling unit is supported at four corners. Which impact factor should be used?
Below are from ASCE
(2) light machinery,
shaft- or motor-driven, 20 percent;
(3) reciprocating machinery or power-driven units, 50 percent;
Thank you!
Below are from ASCE
Thank you!
RE: impact load factor for HVAC air handling unit
