Li-ion Pcb Charger Not Working
I'm trying to charge 4 x #18650 4.2V 4.5Ah Li-Ion batteries. Like these:
http://r.ebay.com/zu9OjA
i'm using this charger:
http://r.ebay.com/6hk1Op
This charger does not appear to be working. Surely my own error. When i charge some good 18650's (not full, but have at least 3V charge), i do not see any of the batteries getting charged. After a couple hours, most of the batteries DROPPED a few tenths of a volt.
What am i doing wrong? Is it a mismatch between this board and the ultra fires? Or maybe these are just fake li-ions?
THANKS!
RE: Li-ion Pcb Charger Not Working
Have you measured the input voltage? You're supplying it with the correct 24V right?
Keith Cress
Compatibility should be fine. How have you hooked it all up? What's your power supply? What are your measurements?
Quote (johnyradio)
how do you know it requires 24V?
It showed your exact same setup on the ebay page with a 24V input supply...
Keith Cress
The product page says:
"Input volt (between B+ / B- VSS-0.3~VSS+26 V"
see op
Quote (johnyradio)
That's between B+ and B-, so that's describing the battery voltage, not the supply voltage.
You want: "Operating voltage 2.0 / 24.0"
Of course, this is just a linear charger, so no charging going to occur at 2V. 24V is a good place to be, but anything above 18V for 4 cells will probably suffice.
i'm using 19v. the datasheet says "Wide operating voltage range 2 V to 24 V"
Ok, success! I managed to discharge and recharge 4 cells.
To discharge, i drove 3 computer fans in parallel off the pack. The controller properly turned off at about 3.5 V to prevent over-discharge. That's a pretty high cutoff, i've read the cells can be discharged to 2.5 V without problem. But future testing my prove me wrong about the behavior of this pcb.
On charging, the pcb stopped charging at about 4.1 V, a bit shy of the standard 4.2.
But hey, at least it works!
I had success with different brand cells than in my initial fail, which may have been the problem. The brand that worked is also an UltraFire knockoff-- one poster said you can get legit cells from some ebay outlets. More testing will be needed to determine how legit these are.
Thanks everybody for your comments!
