How can i import my own load combinations and import to etabs
Hi all,
How can I import my own load combinations and import into etabs, since it is time-consuming to create the load combinations for every new model from scratch.
Another concern is in etabs member design csa s16 default load combinations, there is no snow combination. it looks like I need to create my own snow combination.
RE: How can i import my own load combinations and import to etabs
i've done this before using excel spreadsheet and copied and pasted the result from excel spreadsheet to .$ET file or .Ebk file.
Thanks. let me try it.
Yes, that information can be found in the corresponding ASCI fiels .$et and .ebk.
I use notepad to process them.
Analysis and Design of arbitrary cross sections
Reinforcement design to all major codes
Moment Curvature analysis
http://www.engissol.com/cross-section-analysis-des...
