Tips & Tricks for ADAMS/CAR template builder
Can someone please state the important points to be remembered while building a suspension template in ADAMS/CAR??
Some tricks and tips for ADAMS/CAR template builder are also welcome :)
RE: Tips & Tricks for ADAMS/CAR template builder
Thank you for you reply Greg..
I was trying to run a suspension analysis and in turn i get these errors..
Static equilibrium analysis has not been successful.
The maximum number of iterations 25, has been reached.
For the last attempted iteration:
The equation with the largest error was contact Comp = 5 Error = 705141.910177
The variable receiving the largest increment was fix Comp = 5 Delta = 563645957.821714.
ERROR: Simulation failure detected.
Any solution for this??
