ABAQUS using first result for second analysis
Hi everybody. I'm using ABAQUS to simulate deep drawing process like Erichsen experiment. My model should be two step.
1. I want to pre-deform my sheet metal with abaqus.
2. Then ı want to use this pre-deformed sheet metal and its results with abaqus for another deep drawing process.
My question is: Are there any way to success these operations?
Why ı want to do this. Because I want to model work hardening sheet metal which is in first step and use these result second step.
RE: ABAQUS using first result for second analysis
Else, you can check out restart and import analyses in the manual
