Transformer Lifting Technologies
Hi there.
Anyone know of possible methods for lifting/moving 1500kva and above dry type transformers out of low head room spaces? Anyone know of a mobile hydraulic lift that can be placed undre the transformer and lift it up that way?
Thanks.
b
Thanks.
b
RE: Transformer Lifting Technologies
get it into an area accessible with a proper and then lift using the appropriate lifting hooks, sling and spreaders.
In the mean time, what about something like skoots? We've used them to move switchgear modules of roughly 2 tonnes each and have been impressed. They aren't perfect for all applications and the item being lifted needs to be reasonably sturdy but big awkward objects become very maneuverable. I expect a 1.5MVA transformer will be near the top end of their 5-tonne lifting capability.
The better systems have catch pawls that the ends of the cylinders will drop into when they are retracted after pushing the load along.
I've seen lots of transformers moved this way and it's very effective.
How was it originally installed? Someone has already solved this problem once - look at their solution.
