Part 15 licensing of my product needed?
If I offered my product as "radio control ready" but didn't actually sell the RF control would my product need to be licensed? To operate my product I only need two NO relays from the RC control. I would provide the interface cables but not the RC unit. I'd like to list particular controls as a recommendation for my customers.
RE: Part 15 licensing of my product needed?
Dan - Owner
http://www.Hi-TecDesigns.com
Most anything with modern electronics needs to be inspected, tested and certified by a national regulator (e.g. FCC, IC, etc.) approved lab to ensure it meets the applicable requirements.
This isn't exactly my area, so hopefully the above is accurate.
From what I've read so far it's a fuzzy area. I believe that supplying an interface cable to be used between the "approved" receiver and my product might require my product to be certified. I also think that by calling my product a radio controlled device I might need to have my product tested as a non-intentional radiator.
TTFN
Dan - Owner
The requirement and process apparently even applies to unintentional emitters such as receivers.
I'll take a look at "FCC Declaration of Conformity"
Dan - Owner
If you are using a radio transmitter in your product then you need to be tested against FCC Part 15 limits for an intentional radiator and get your system certified.
A radio manufacturer claiming they meet FCC requirements is only stating that their device passes, so there is a high probability that you can implement it in your system without issues.
Z
Z
