how to split and join files
Hi everybody,
I have to run an fluid structure interaction model for almost 30s but after 1 second, the computer becomes hanged and after some time everything shuts down showing that your computer does not have enough memory. I use workstation with 32 GB ram. I have tried to run this a lot of times, but the situation is the same. So, I thought that I would split the hole analysis by 30 segments and run each of them manually. If I do so, then I will have 30 odb files which I have to join. Can any body tell me how to do this splitting and joining? I have to run another analysis by submitting the whole joined odb file as an input. I have heard about restart and joining but don't know how it works. Is it possible to do anyway? If anybody can help, I would be grateful.
Pratik
Pratik
