stp file failure from CatiaV5 to Solidworks
I am sending STP files that I am exporting from Catia V5 R20 to a customer who is using Solidworks (revision currently unknown). These assemblies import ok apart from cable routings which have been modelled mainly using the rib function. Some of these parts view ok but the rest appears corrupted with the curves fading to nothing. I've tried the four version of .stp available on the options with the same end result. Any ideas
Thanks, Ian
Thanks, Ian
RE: stp file failure from CatiaV5 to Solidworks
