Change in areas number in an opt analysis APDL
I´m trying to make an optimization analysis.
In my original analysis I have all my loads and contact elements in certain areas, when the program changes the parameters some areas changes their number and the loads are applied in erroneous places. Someone knows why is happening this?
RE: Change in areas number in an opt analysis APDL
you need to select areas by location: asel,s,loc,x,..
alex
MESHPARTS
Tuning Your Simulation
http://www.meshparts.de
Have you tried naming those. Using named selection you can specify the parameters whose dimensions you want to change.
If I didn't answer your question, that's probably because I didn't understand your question. Thanks
Joseph George (Student)
M.E Machine Design
Sardar Patel College of Enginering, Andheri (W)
Mumbai, India
