SW Liquid Filled Vessel Section View
I've been working on a liquid filled section view of this vessel for a few days now and my renders aren't coming out well.
I've attached an example. This is what you're looking at...
- I cut the vessel in half.
- The liquids, water and oil, are hallowed out cylinders that sit inside the vessel. This way they don't block anything from view.
- There are two Point Lights that illuminate the vessel, you can kind of see their hot spots.
The goal is to make a flashy flow diagram that eventually we will animate.
Does anyone have any suggestions on how to "fill" this vessel? I've tried different lighting and changing the liquid materials, but the results are darker or washed out.
RE: SW Liquid Filled Vessel Section View
Scott Baugh, CSWP
FAQ731-376: Eng-Tips.com Forum PoliciesBerry Plastics
Cad Admin\Design Engineer
GEASWUG Greater Evansville Area SWUG Leader
www.scottjbaugh.com
