Have a Application for ASTM 516 Grade Plate vs 4130 Round
I have an application that uses ASTM 516, Grade 70 Plate. I can get it flamed cut to the sizes I need, but for large quantities, it is very expensive. Is there an alternative material I can use. Say the likes of 4130 Material in round bars. Would be cost effective if this were possible
RE: Have a Application for ASTM 516 Grade Plate vs 4130 Round
That certainly is one option. Difficult to give you any further advice without knowing anything about the end use, etc.
