IGES Export Problems
Hey y'all,
Due to a plugin issue with ANSYS, I cannot import a .prt or even a STEP file. My only hope at the moment is to import an IGES. However, I am having issues creating an IGES (NX7.5). I have a part file that contains a single solid body. I have checked and re-checked that it is a SOLID body and that it contains absolutely NO SHEET bodies. However, when I choose to export the single solid as an IGES, when I re-import the IGES to check it, it has turned into about 200 sheet bodies. I am not really sure what to do here. I have heard that IGES are not ideal due to inaccuracies, but I have had luck in the past.
Any thoughts? Thanks.
NX7.5.5.4 - Teamcenter 8
ANSYS Workbench 14.5
RE: IGES Export Problems
