corrision of 2205 in concentrated salt soultion
Thinking of building a large evaporator to concentrate salt solutions to 25% +/-.
Planning to use 2205 tubing and contact surfaces. Vapor surfaces will be 316L
Any experience?
Thanks Jtgevoc
Any experience?
Thanks Jtgevoc
RE: corrision of 2205 in concentrated salt soultion
I can't see 316 working if any liquid contacts it at all.
Plymouth Tube
Probably run seven effects forward flow evaporator, single pass.
If my first effect is at 100 degree C at 3% salt, will the 2205 work?
(I assume this will be the most severe condition).
The last effect will be at about 50 degrees C and 25% concentration.
I can build the entire evaporator out of 2205
Thanks JTGVOC
