This is embarrasing
This is embarrasing
I started to use SolidWorks this morning, started a sketch and I'm not able to modify the dimension. Sketch circle, size shows up highlighted, try to change and it will not take the new dimension. This was working fine last night, I have rebooted the computer several times and it has no effect. I have opened up parts I did last night and I can't change dimensions on sketches. Anyone have any idea what might have happened?
Thanks in advance
Dennis
Thanks in advance
Dennis
SolidWorks 2013
Dell Precision T3500
Nvidia Quadro 2000
Dual Monitors
RE: This is embarrasing
Did a Windows update occur & change something it shouldn't?
Try rolling back to a Windows Restore Point.
Make sure you haven't accidentally hit Num Lock and turned off the keypad! It would still accept entry with the top numerical keys and scroll wheel.
Just a thought
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2013x64 SP2.0 Intel Core i7 2.94Ghz, 12Gb Ram, NVIDIA Quadro FX3700 Driver: 6.14.11.9100
SW2013x64 SP2.0 Intel Core 2 Duo 3.17Ghz, 8Gb Ram NVIDIA Quadro FX3700 Driver: 6.14.11.9100
You hit it right on the head. I started using a new Microsoft wireless keyboard and mouse. Love it but it does have a short coming, no indicator lights so you have to hit a key to check it's status. Sure enough it was the damn NUM LOCK key. Thanks guys for the quick response.
Dennis
SolidWorks 2013
Nvidia Quadro 2000
Dual Monitors
In windows there is an option to play an alert sound or visual cue when a control key or numlock is toggled. At least you didn't clear the Delete key from your kbShortcuts
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
CSWP, CSWI, CSWTS
Follow me on !w¡#$%
@ TrajPar - @ mcSldWrx2008
= ProE = SolidWorks
