Change Material property during iteration step
I'm fairly new to Abaqus so bear with me:
I'd like to change material properties during a jobs iteration frames e.g. at the second iteration step id like to change my young's module to e.g. 10^9.
How do i do this?
My final goal is to evaluate each mesh element after an iteration and change its material properties depending on the stress level.
Thank you for any help :)
How do i do this?
RE: Change Material property during iteration step
Abaqus feature you are looking for is called field variable.
Check Abaqus documentation: Abaqus Analysis User's Manual, 33.6.1 Predefined fields
To do it you need to use field variable in combination with FORTRAN subroutine USDFLD/VUSDLF and GETVRM/VGETVRM routine.
Use "field" and "usdfld" as keywords to search posts on the forum.
You can find many with detail information how to do it.
Bartosz
