NX 7.5 takes too long "Updating objects..." while editting a sketch
In NX 7.5, is there a way to turn off the "Updating objects..., Updating Feature 1, Updating Feature 2, ...etc." while editting a sketch? In my example, a sketch is used to make an extrusion. This part has ~350 features in the part navigator. When I update any sketch, NX will take about 33 seconds to update the entire part navigator every time I do one of the following:
(a) add a line to the sketch
(b) add a constraint or dimension to the sketch
(c) trim a line in the sketch, OR
(d) change a sketch dimension.
It is extremely time-consuming to wait this long for "Updating objects..." for each small change to the sketch. Is there a way to quickly make multiple changes to the sketch, without "Updating objects...", and then when all sketch changes are complete, have it update the model? Thank you.
Joe
mechanical engineer
Joe
mechanical engineer
RE: NX 7.5 takes too long "Updating objects..." while editting a sketch
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
