Mating and moving prblem
I have two equal rings with 6 holes in a circular patern. These rings are kept apart by small spheres that fit in those holes. To align the rings i use a coecentric mate between the faces of the iner holes. My problem is when i try to move a ring to touch the spheres the whole assembly moves as if it was a single part.
Could someone help me ?
Thanks in advence
Thanks in advence
RE: Mating and moving prblem
You still need to fix a part and constrain it to the origin somehow.
Scott Baugh, CSWP
credence69@REMOVEhotmail.com
http://www.3dmca.com
http://home.insightbb.com/~scott.baugh/
*When in doubt always check the help*
Then I assume you'll use a TANGENT mate between the surface of one sphere and the nearest edge of one of the holes.
But - Scott is right - step one is to fix at least one of them rings.
